Putting CTR pistons into b16.
allmotorb16civic
I'm thinking of putting CTR pistons into my first gen b16. What compression would I get and can I run 91-octane fuel safely? If not would it be worth it to get ITR pistons?
um, your compression would not be affected, but you might wanna get new valvesprings and retainers because the ctr's make power above that of the b16 cams. you would not want to put in itr pistons, as they would either cause the same c/r if not reduce your c/r because they are meant for the itr stroke which is longer than that of the b16...your best bet would be getting ctr pistons.
yeah it would, you are thinking cams
itr pistons do not directly bolt onto b16 rods... some modification is needed however ctr pistons are plug n play
show me a piston that "bolts" on to a rod :wacko:
as far as i know all b18 or b16 pistons can be used on b18 or b16 rods
i have stock jdm b16 pistons pressed onto stock usdm ls rods in my ls motor
LS rods and B16 rods can use CTR pistons or B16 pistons. But If you want to use ITR/GSR pistons you have to shave the piston because the rod is wider.
Originally posted by wildbillhatchbac@Sep 17 2003, 03:05 AM
usdm b16 c/r = 10.205320397414986
usdm b16 with itr pistons = 10.194654591216547
usdm b16 with ctr pistons = 10.801068956759683
this can all be found on this site which i found in the HS FAQ forum when building my motor http://www.c-speedracing.com/howto/compcal...lc/compcalc.php
*edit . . . i'm running 11.1 to 1 compression and use 93 or 94 octane at all times
that compression calculator is garbage.
there is no way CTR pistons in a B16a block gives it only 10.8:1 CR, that is the CR of CTR pistons in the B16B!! and the B16B have the same deck height as the gsr/itr blocks, that compression calculator thinks the B16a/b blocks are the same... no way jose. CTR pistons in a B16a wil give you around 11.6:1 CR
When I bought my LS I bought it to VTec it. Now It does so good I am going all motor LS!
9.10 ET 1/8 mile
60ft-2.00
76.99 MPH
95 DX coupe w/ must of the interior (no seats) and MT ET slicks
I/H/E and regrinded cams and that is all.
yes you can run 91 octane on that motor you wanna build..2 reasons,1 thats all there is bro.2 can normal type-r's run pump gas-yes...good luck..tell me how it runs when your done
if you put CTR pistons in a B16a block, you will have a higher compression ratio than any type-r, so your point B is not valid.
you should be ok on 91 octane, get it tuned.
Originally posted by B16+Sep 17 2003, 05:29 PM-->
kingwilly
Mike, you shoot down reason #2 and don't say ANYTHING about reason #1????????? How bout 93 octane? Or 100? Or 110? It's called race gas guy. Thanx for the worthless post though.
Originally posted by sohcslammer+Sep 17 2003, 03:29 PM-->
Originally posted by B16@Sep 17 2003, 05:29 PM
kingwilly
haha, guess point 2 was the only one that caught my attention :p
wow..i wasnt trying to be all technical..bottom line 91 gas should work..if not then something isnt right
