Putting Motor Together
Discussion in 'General Tech and Maintenance' started by Viperlocc_B18C1, Jun 13, 2003.
  1. Viperlocc_B18C1
    Viperlocc_B18C1 Senior Member
    Madison, WI
    right now im in the process of throwing the pistons in the block and putting the head back on.
    how do you hone? i need to use a hone (new pistons) and im renting one but how do you do it?
    and can i use the original head bolts for like 2 weeks..if that cuz im short on money....if i torque them down a little harder i think i can get away with it right?
  2. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    oh no, this sounds like a high school science project. If you don't know what your doing please give it to someone who does. There is a tq spec for a reason.
    Milan
  3. SixtySecondAssassin
    Austin, TX
    over torquing would only put more initial stress on bolt
  4. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    I have been told that honda head studs are for one time use only, is this true? and if so, I would recommend waiting till you got some coin so that you can replace them...
  5. B16
    B16 Super Moderator VIP
    yay area, CA
    yes, you have seen my broken head bolt from reuse, that was at only 15lbs
  6. MaaseyRacer
    San Francisco, Ca.
    that is right you are the one who told me that, and I saw the bolt too... yeah man get new ones...
  7. Viperlocc_B18C1
    Madison, WI
    for ur info its not a highschool project..ive went from a supra to a honda and yes, the motor is way different as you can use the same headbolts that were taken out. some people on honda-tech say you can re use as one guys has been on his turbo motor...but i prolly wont chance it. and was told by a machine shop its not needed to hone as it can cause more damage...but i have to check for scoring as i didnt see any
  8. D See 2
    D See 2 Senior Member
    Baltimore, MD
    honda head bolts are NOT torque-to-yield (one time use) bolts. i personally called honda myself and asked if new bolts were required and they said no. then again heads are not meant to be taken off like every other week so i would only re-use the bolts 2 more times at most. and please do not over torque them.
  9. Gen2Teg
    Gen2Teg Senior Member
    san francisco
    i would just use new head bolts
  10. JDMilan
    Boca Raton, FL
    Viper, I was being sarcastic. I would replace the head bolts and a good starting point would be the old one's site on info regarding "honeing".
    Milan
  11. Viperlocc_B18C1
    Madison, WI
    bah, arp head studs are ordered...hell with it..i want it done right the first time, no half ass job...so blah
  12. B16
    yay area, CA
    mine broke from just taking the head off once. i'll never reuse again, just from personal experience. i dont like the idea of getting another one stuck in the head.
    glad to hear you got new ones, great insurance to have :)
