UNDR8D
...has a job!
95 EJ2, fuel pump is not turning on and pressurizing in key on. I jumped the pump with a battery and it works so I know the pump itself is fine. I am just finishing an LS swap and I have not reconnected all the grounds yet. From experience, would the fuel pump not run because of a ground? Also, is there a separate fuel pump relay or is it run off the main relay, the gray one down by the driver's side kick panel? In all my searching and rambling I could not find a fuel pump relay or any pertinent information about it. Thanks guys.
