The PW0 has the same support the PR3 does. Although both are different, their support is somewhat similar. Look into Turbo Edit. However, obd-1 has a ton more support.typej said:Is there any faith for the PWO Ecu (OBD 0) or is it no good? Basically are there any tuning software for it or am I basically going to have to step up to OBD 1 STATUS?
B16RacerN2NR said:The PW0 has the same support the PR3 does. Although both are different, their support is somewhat similar. Look into Turbo Edit. However, obd-1 has a ton more support.
\cypher said:wont chrome work on pw0?
are you sure about that? pw0 + chip and chrome tuninig is not possible.MikeBergy said:\
(big breath) - HAHAHAHAHAHAHAHAHAHAHAHAHAHHAAHAHHAH......AAAAAAHHHAHAHAHAHAHAHAHAHAH!!!!!!!
No.
Taco15 said:are you sure about that? pw0 + chip and chrome tuninig is not possible.
MikeBergy said:correct, not possible.
pw0 = obd0
crome = obd1
