Q about cam
Discussion in 'Engine Building' started by b18b, Nov 10, 2002.
  1. b18b
    b18b Senior Member
    what exactly are jg 301 good for? what kinda gains? if someone knows anything about them or a web site that i could find somethin out about them i would appreciate it....thanx
  2. CRX-YEM
    Wallingford, CT
    can you post the specs on that cam, it'll make it easier to hepl ya out. not everyone know s the specs just by hearing what type it is. things needed to know.
    advertised duration at .050
    intake lift and duration
    exhaust lift and duration
    lobe center angle
    those numbers would help out a bit.
    and if you have these numbers it'd be even more descriptive
    int opens int close exh opens exh close
    exh stroke int stroke pwr stroke exh stroke
    BTDC ABDC BBDC ATDC
    those number would be in degrees.
  3. b18b
    b18b Senior Member
    thats just it i dont know any specs on them
  4. pissedoffsol
    from what i can find- they appear to be turbo cams....
    and some LS's running them have mad some pretty damn good power.....
  5. CRX-YEM
    Wallingford, CT
    wtf is jg an abbreviation for ? I'm looking for their web site but can't seem to find it
    also some info I ran across
    JG cams are all regrinds, meaning that they are all smaller than the
    factory spec and have smaller base circle. Most people with JG cams
    have to adjust their valves very often
  6. pissedoffsol
    regrinds suck.
    JG is now JG Edlebrock... so these cams you are looking at are pretty old to say the least
  7. b18b
    b18b Senior Member
    alright thanx for the info!
