Quaife Lsd Install Help, Please
If anybody has intalled a quaife in a b series tranny please respond. I have questions about my install and any info would probably be helpful. Please, this has been apart for weeks now and I really want to drive my car.
I have installed several, you will have to ask a question first before I can give you any advice.
I am replacing the factory lsd in y1 tranny with quaife. The 10 final drive bolts dont fit into quaife. Do you know what bolts to get. Also is it reverse threads like the honda one
Also what is the quaife part # you ordered, I would need to know that too.
My best guess is that you need to order final drive bolts for a b series tranny that is newer such as the ls or gsr that is a hydro tranny. I bet quiafe used the same size bolts as these for your differential. They should most likely work but if you want to be sure contact quiafe directly and ask.
