question about b16 SIR II
Discussion in 'HYBRID -> ED-EF / DA' started by mezzmerizzencrx, Dec 11, 2003.
  1. mezzmerizzencrx
    mezzmerizzencrx Member
    SJ, CA
    i'm new to this hopefully i asked it in the right place. i wanted to know how i can identify that my B16 SIR II swaped into my 88 crx si is really a SIR II. Just want to make sure and wat ecu should i be using for it. i'm using a pr3 right now n it seems like its messed up cause vtec crossover is at liek 4500 and fuel cutt of is at around 7600. any help would be good. just making sure i paid for wat i got. Thanx
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    So are you asking how to tell if you really have a B16A? If that's the case, look at the block on front next to the transmission, there is a small square with B16A and then the serial number under it.
  3. mezzmerizzencrx
    SJ, CA
    i know its a b16 by the front of the block no doubt, wat other way can i tell if its a 1st gen or a 2nd motor? they told me its a 93 EG JDM 2nd gen motor. is there some other stamping that would show wat gen it is?
  4. brian11to1
    brian11to1 Senior Member
    the color of the plugs... whitish OBD-0 roundish (distributor at least). greyish and square (distributor side) OBD-1. I believe.... someone confirm this.
  5. xj0hnx
    C.C.TX.
    THere are a series of numbers on the head on the leftish side under the heatshield...
    looks like this...
    The number on the left is the date the head was cast, not nescessarily when it was installed by Honda, as mine came from a 93 civic VTi.
    Also the plugs are milky white on the first gens, and the serial number starts with 1.
  6. Cashizslick
    1st gen should use a cable tranny - and check the plug color.
  7. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    I believe a PR3 is an OBD1 ecu, or at least they make an OBD1 PR3 ECU, and I believe it came with the 92-93 XSI. Also SIRIIs came with hydro transmissions, did you put a cable one on? Are you using the HASport kit for a hydro tranny in an EF?
  8. mezzmerizzencrx
    SJ, CA
    thanx this would help. If more please post.
  9. mezzmerizzencrx
    SJ, CA
    i got a cable tranny put in instead
