Question about brakes.
Discussion in 'Civic and del Sol - EG and EK' started by 92stoccord, Jul 10, 2010.
  1. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
    Took the wheel off today and found that the impact screws are rounded the fuck out. Ones broke off and one is pretty bad in the middle. My question is, should I replace them? If I can't get the rounded one out should I drill it out or what? I have an impact driver, I'm just not sure what to do about it.
  2. ilovekandypaint
    ilovekandypaint resident paint pro
    I had an ef same thing. Had ppl tell me it didn't matter if the little screws were there or not. Drove it probably 15k miles without them. I really don't see what they do.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Not necessary- but I've always replaced mine.
  4. 92stoccord
    Salem, Ohio
    Should I get them from Honda or what? Drilling them out isn't going to hurt my hub at all?
  5. efhondakid
    Akron-Canton, Ohio
    Neither of my cars have them, the EF had one in it when I bought it and the EG didnt have them at all. If you drill the head off the screw enough to pull the rotor you should be able to grab it with a pair of vise grips once the rotor is off, and remember heat is your best friend.
  6. wikedeye
    wikedeye Well-Known Member
    Savannah, Ga.
    I have drilled mine out before and just replaced them with home depot screws on the cheap.
  7. Dual-500
    Dual-500 Well-Known Member VIP
    Fort Worth, Texas
    Same here.
  8. ilovekandypaint
    What are they really for? Doesn't look like they go to anything. They sure as hell don't hold the wheel on or the caliper, so what use are they?
  9. phunky.buddha
    Hold the rotor in place before you put the wheel on, keep it centered etc...
