question about brakes...
Discussion in 'Wheels / Suspension / Tires / Brakes' started by scottp11, Nov 2, 2005.
  1. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    I'm thinking about ordering the JDM rear disc conversion from the 92-95 civic Sir. (which comes with the proportioning valve) :) I was wondering if the rotors and the pads are the same as the 92-95 civic Si, so when I replace 'em, I'll know what to get. Also, I want to get an Integra GSR or Type-R master cylinder. I was wondering if I could use my CX brake booster or will I have to get the Integra one also. Thanks for all your help! [​IMG]
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Yup, the rear setups should be the same.
    Nope, you can't use your stock booster with an Integra master cylinder- you'll have to swap to the Integra one or go with a 90-91 Civic EX master cylinder. The "ears" are clocked opposite between the Civic and the Integra.
  3. scottp11
    Is the 90-91 EX better than my CX booster and master cylinder. Did the 90-91 EX come with rear discs?
  4. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    The ex master cyl has more volume.
  5. scottp11
    Will only 90-91 EX booster and master cylinder work or can I get one from say a... 92-95 EX, Si or 96-00 EX, Si? If so, are they as big or bigger than the 90-91?
    Thanks again!
  6. scottp11
    Anyone? Cuzz there's a bunch more 92-00 civic's at the junk yards around here than older one's...
  7. pissedoffsol
    not 90.
    JUST 91
    and ONLY the 4-door sedan EX. the 2-door doesn't have the right part.
    it uses a 15/16" master cyl, bolts to the stock EG booster and hardlines w.o bending.
    you can pick up a remanu unit from autozone for $45 + core charge (just shove your cx one in the box... good enough)
  8. scottp11
    Thanks man! Will do. And defidently will put the CX one back in the box!
