onefiine69
I recently bought a 98 civic DX with blown motor for $500 So I bought a used engine from Noyan USA to go in its place. I come to find out its actually a SOHC ZC motor from japan. So i had to change the intake and a few other things (no big deal). But the other night I started to hook the wirring harness back up and came across a problem. The Distributor is diff and the ZC doesn't have a crank sensor that the D16 had? What do I do to convert it and make it work? I called a friend and he said something about rewire the DX dist harness to the ZC style connector and that should work?
Is this true and if so can someone tell me what wires need to go where?
Thanks
Erik
Thanks
Erik
