Question>> About L3 Trans
Discussion in 'Civic and CRX - EF' started by ceehris, Nov 29, 2006.
  1. ceehris
    ceehris New Member
    Vancity, Canada
    I have a D16Z6 in a 88 lx. I did not do the swap.
    Im not sure if the person who did the swap used the stock tranny or
    if they used a si tranny.
    So my question is how would I be able to tell if it is the Lx tranny or a Si tranny?
  2. fasterimage
    fasterimage 2 SLOW CREW
    State College, PA
    I'd get under the tranny and look for some number on it then research the number u find....prolly ur best bet!
  3. ceehris
    ceehris New Member
    Vancity, Canada
    probably. but im sure somebody around here knows exactly what number to look for and where and what the number means.
  4. jlicrx
    jlicrx Senior Member
    Colorado Springs
  5. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    you should be able to tell by the feel of the tranny. there is a large drop in rpm between 1st nad 2nd if you have the lx trans. i found that reikoshea has a sticky on this. you should go check that out when you find the numbers on your trans. it tells you the gear ratios of the trannies and what models they come in. i'll try to pull up the link.
    http://hondaswap.com/reference-materials/honda-transmission-specs-29132/
    that should take you there.
  6. ceehris
    ceehris New Member
    Vancity, Canada
    HUGE PROPS guys thanks alot for all the info!
