Question B16a1 first gen in ek
Discussion in 'HYBRID -> EG-EK / DC' started by 1FastEk, Mar 16, 2004.
  1. 1FastEk
    1FastEk Junior Member
    Just Wondering all I would have to change to allow the 1stgen engine to run in the ek besides the dizzy and the altenator just woundering thanks.
  2. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    convert to cable for starters, run a different ECU setup, and conversion harness, HASPORT upper tranny mount since it's different for the cable tranny into EG's and EK's.
    honestly, I would pass the idea.......it's really not worth it in the end, why? because I did it
  3. E_SolSi
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    :werd: :withstupid:
    Cable to hydraulic tranny adapter, complete intake manifolt, to include all injectors and sensors, Distributor, ECU.
    You're looking at cost more to put the cheaper motor in.
  5. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    Yep, I did it and now I'm spending more just to get it running right. Go with OBD2!!!
  6. JDMilan
    Boca Raton, FL
    ^^ yup, just because the motor 'first gen' is complete and cheap, doesn't make it the best solution.
    if anything in your case I would advise to save up the extra cash and get an obd2 GSR motor.
  7. 1FastEk
    This is just a motor i can throw in for a lil power I had my gsr in it spun a bearing now im going B20 ohh ya and as for the cable to hydro why cant i just use my 00 si hydro tranny still. So whatdo i have to change.
  8. xj0hnx
    C.C.TX.
    Well Gomer, because you failed to mention that you had one. There for no more answers, till we know what you're working with.
  9. E_SolSi
    i love it when asshats leave out 90% of the most important details
    :bash:
  10. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    read my sig y0! :D
    change the intake manifold, alternator, dizzy, injectors, wiring harness, transmission...
    actually, it isn't all that hard to rig up a cable tranny in a hydro car...emphasis on RIG....pretty much just run the cable to your clutch pedal....like i said, rig....i've seen it done....
    obd0 mothafucka!!!
