question for people with obd0 b16a swap
mrme
does ur car bog alittle at the low rpms(750-2000)? not as a bad bog, but alittle laggy? j/w..heard somewhere tat this is common for b16a swaps..frnds got a 90 crx w/ jdm obd0 b16a
Check all your grounds, I have the sme swap and mine did that because I didnt have the ground hooked up for the vtec pressure sensor. Do you have any codes/a CEL?
no codes....code 7 for tps was on 4 a bit but then when off n hasnt come back on for about a week now...but will check the wire
