Question on 18x9.5in wheels
Discussion in 'Wheels / Suspension / Tires / Brakes' started by CivicEX88, Nov 11, 2009.
  1. CivicEX88
    CivicEX88 New Member
    new to the forum and i had a question...What are the pros and cons for putting 18x9.5 wheels on a civic EX 2004, if possible....i have had no lowering or anything done to my suspension..Thank you...
  2. Briansol
    way to wide, will ride like crap, rub everywhere, look retarded to boot. you need to lower if you're adding big wheels. it will just look retarded 4x4 edition without it.
    there are no pros.
    17x7.5 is as wide as i would go...
  3. 94civicturbo
    94civicturbo New Member
    Liberty, IN
    they're 18's on a honda... that should say it all.... and the stuff he said is good reasoning too
  4. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    there are no pros... just a lot of cons
  5. CivicEX88
    so should i stick with 17's instead?....thank you for the feedback
  6. eg6sir
    IMO, i wouldnt go over 16's.. but thats me..
  7. FLounder
    i think that 16s are the best size to go with as well, but if you like the look of big wheels then get 17s. pretty much any aftermarket wheel regardless of size is going to look funny without lowering the car at least a little.
  8. 95b16coupe
    95b16coupe New Member
    ct
    16's are the biggest you should go on a honda. wheels that are 18x9.5 are meant for some bigger rwd cars like nissans and shit.
    i can't even find pictures of a honda with 18's to show you how stupid it looks..
    but those wheels you are looking at aren't meant for a honda. they probably aren't even 4 lug. do you have a picture of them? i'm assuming you are asking because you found a set you considered buying.
  9. Matts96HB
    Matts96HB . Moderator VIP
    Pros: None
    Cons:
    That is all.
  10. 95b16coupe
    ct
  11. TurboMirage
    i have 17x7.5 on my mirage... no issues or rubbing even dropped, but that doesnt help you ;)
  12. 95b16coupe
    ct
    your mirage also looks like a 4x4 lol
  13. awptickes
    MD
    Yeah, but a mirage is the car a civic wants to be.
    And btw, his mirage doesn't look bad at all with the street wheels on.
  14. Briansol
    this thread is full of fail
  15. 95b16coupe
    ct
    i didn't say it looks bad, it just rides high. which is understandable with the body kit and all.
  16. Matts96HB
    And it all started with my epic pic fail. Thanks photobucket. :(
