question on a 90 swap crx
reasonlost
hey what up guys ok straight to the point this is whats going on dudes:
first i'll tell u what i did to the car
1990 crx dpfi automatic
swapped to d16z6 enine block with a y8 head sohc vtec
now i have done the auto to manual swap already and also the dpfi to mpfi conversion i used an obd0 si distribuitor and pr4 obd0 integra ecu everithing plugged in with the appropiate wiring conversions well the thing is that when its time to turn it on it wont
it sounds like it'll go but i get no spark or gas
and when i turn the key to the on possition the ecu blinks but turns right off
what do you guys think it is ?????
am i fucking up somewhere in the process??
help
:mellow: thanks
you should use the ecu thats propper for the head your using obd2 and it also sounds like your main relay has gone bad so check that first
like he said switch out ur ecu becuz it's obd2 even my crx ecu does that to me to0 and check if ur gas pump is pumping gas or check your throttle sensor.
