question on a garrett turbo
Discussion in 'Forced Induction' started by 96civic808, Mar 1, 2010.
  1. 96civic808
    96civic808 New Member
    there are 4 holes
    one is feed, return what are the other two holes?
    is this for water cooled?
    and the oil are for lubricant?
    <a href="http://s603.photobucket.com/albums/tt119/alwayz6879/?action=view&current=DSC00219.jpg" target="_blank"><img src="http://i603.photobucket.com/albums/tt119/alwayz6879/DSC00219.jpg" border="0" alt="Photobucket"></a>
    <a href="http://s603.photobucket.com/albums/tt119/alwayz6879/?action=view&current=DSC00216.jpg" target="_blank"><img src="http://i603.photobucket.com/albums/tt119/alwayz6879/DSC00216.jpg" border="0" alt="Photobucket"></a>
  2. 96civic808
  3. 95EGCoupeVtec
    95EGCoupeVtec SOHC VTEC at its best
    South Mississippi
    yes those should be for water cooling. idk if u can bypass them or not, i dont think you can.
  4. silver
    silver Senior Member
    St. Louis
    People often do bypass them. If you choose to do so, make sure you give your car adequate time to cool down after spirited driving to avoid coking the oil inside the CHRA.
  5. 96civic808
    so i have to run the oil lines?
    how can i bypass the water holes?
  6. Matts96HB
    Matts96HB . Moderator VIP
    get plugs for them from a hardware/pipe/hose store
    yes you must run oil lines
    or the turbo wont last long.... at all
  7. 96civic808
    so pretty much connecting the two water hole together?
    if i wanted to run the water lines how would that be? where do run in to?
  8. silver
    St. Louis
    You have to tap into some coolant lines, probably off the front water pipe.
    You need oil as it provides the film separating the turbine shaft from contacting the walls of the CHRA.
  9. Matts96HB
    no, just plugs for those holes in the turbo's core.
    i think he was talking about blocking the two water ports on the turbo off completely..
  10. 96civic808
    ok tnx.
    k now, how do i check which holes for the oil/water holes.
    btw what is CHRA?
    i apologize for the noob question.
    new to this stuff
  11. 96civic808
    how can i tell which one are for the oil or water holes?
    for d16 where should i tap the feed/return water line if ever i wanted to run the lines?
    btw what is CHRA?
    tnx!
  12. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    You dont even need to plug the holes for the coolant. My turbonetics turbo has a water cooled section and I dont have anything hooked up to it. Nothing is going to leak out of it, lol! Like other people said just let your car cool down a couple of minutes before shutting it off.
  13. HA Motorsports
    HA Motorsports New Member
    DO NOT BYPASS THE COOLANT LINES ON A WATER COOLED TURBO!
    Water cooled turbo's need to have the water cooling them. You are going to boil your oil if you do not.
  14. Matts96HB
    ^ is the smart way to do it
    question was asked, so i answered it :shrug:
