QUESTION TO ALL TPS SENSOR H22A4
Discussion in 'HYBRID -> EG-EK / DC' started by xflipwarriorx, Oct 8, 2003.
  1. xflipwarriorx
    xflipwarriorx Junior Member
    want to know if all honda tps sensor work on all honda engines. irratic idle on 2k RPM throttle caused by TPS sensor?
  2. ProspeedCTR
    ProspeedCTR Junior Member
    Somewhere You Wanna Be
    Yes I believe that any Honda TPS sensor will work. I know you can put a SOHC TPS on a DOHC so it should be the same for the H series. If it does turn out to be different I am sure a TPS sensor will work off an F series.....
  3. xflipwarriorx
    thanks for reply, i'm goin to try a 91 accord tps tommorow see if works.
