Question...
Discussion in 'Engine Building' started by chris3385, Nov 3, 2002.
  1. chris3385
    chris3385 Junior Member
    I want to know what I would need to get my stock '93 Civic Si Vtech motor have between 275hp and 300hp. Please reply....
  2. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    I say build the internals up and boost that biatch! You use stock internals, but wont get the amount of power you want.
  3. E_SolSi
    definatly build up the internals and boost it
  4. bte15
    bte15 Senior Member
    Bellevue, Washington
    you would be better of going with a b series or even an h series if you want that much power that little engine will be highly unstable at best trying to get that much power out of it
  5. E_SolSi
    the D series will be fine ... you just need to do it right and build up the bottom end to handle it ... if built right you can get over 400hp out of a D series
