questions about interchanging parts on 90 accord coupe
Discussion in 'Accord' started by 1990cb7, Jun 30, 2011.
  1. 1990cb7
    1990cb7 New Member
    My mom gifted me her 1990 accord 2 door the other day and I'm trying to fix some minor things with the car. First off, I want to ditch the front and rear seats in place for maybe gsr seats and was wondering if they would fit or would I have to make some hardware changes? Secondly, I have a leak in the trunk and I'm thinking its the rubber molding. Are there rubber replacement kits out there for the entire car? Because the doors need it as well. Is there something on the market that i can condition the exterior moldings with? And lastly, I would like to swap out the steering wheel for another newer styled one like from a newer accord, civic or prelude. Will those swap out with no problems? 1 last thing, I've seen people swap the f22 for an h22 or h23, and was wondering if the motor would drop rght in without modifying anything. What f series motor is also a good direct replacement for the f22 in my car currently? Thanks for any help!
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    You can probably do a pan swap, but seats do not readily interchange.
    I never seen any; you probably have to get those from the dealer.
    Trim paint?
    Can't say; I've only heard of Prelude steering wheels swapping over.
    Yes: F and H share the same mounting points and transmission bolt patterns.
    Any newer engine would work. In general(from a performance stand-point), the F22A1/A6 are highly regarded due to the intake ports.
  3. 1990cb7
    1990cb7 New Member
    So you don't have to do any special motor mount additions like when you swap a b series into a civic? Also, how hard is it to change from an automatic to a manual trans?
  4. K2e2vin
    Raleigh, NC
    Nope.
    Can't say; I never had to do it.
  5. 1990cb7
    1990cb7 New Member
    Thank's for the info. If I think of anything else I'll post it
  6. 1990cb7
    1990cb7 New Member
    I thought of something else I wanted to ask. Will the axles for the accord work with the h22/23?
  7. Korax
    Korax New Member
    Western PA
    Transmissions are interchangeable between F/H so I would say yes.
  8. 1990cb7
    1990cb7 New Member
    Speaking of transmissions, the tranny in my car "hiccups" while driving on the highway. The transmission was inspected about 40k miles ago and it was deemed to be in good shape. The only thigh mentioned was that possibly the linkage was "tight" because when you go from park to reverse the linkage seems a little stiff. Any ideas?
  9. Hondadude141
    TX
    Does it slam into any gears? Sounds like a servo to me, but I need to to know what you mean by "hiccup"...
