questions about sensors
intafocus
i went to the pic and part and pulled random sensors off differnt d15s like the coolant sensors and oil ones that are in drilled the block and on the block where the back coolant lines go in from a pic and pull does it matter if its obd1 or ob0 for those ones
ok cool lucky the ones i needed all fit but i just wanted to mke sure theyd all work
what do you have?? obd1 engine? the fan switch on obd 0 is located near the oil filter and on obd1 its on the thermostat housing and its a diff type of sensor
