Quick 92 eg question
Discussion in 'ECU's, Electronics, and Tuning' started by jgpoirier, Mar 22, 2011.
  1. jgpoirier
    jgpoirier New Member
    I have heard that only the 92 hatchs came with vtec wired from the shock towers to the ecu. But then I read this yesterday http://www.ff-squad.com/tech/wiring/wiring.92-95.jpg near the bottom in the notes section states that ALL 92 civic and del sol models came wired with vtec. I am about to do my B16 swap into my 92 lx sedan this Friday and all I have left to do is wire vtec and knock sensor. I have an si harness already, but I am very curious if this note is true? I am going to rip down to the ecu in the car currently and inspect to see if the A4 and D6 locations are terminated with the proper VTEC wiring. But does anyone have a confirmed answer to this?
    Thanks,
    Guy
  2. haao13
    haao13 New Member
    PA
    im pretty sure all 92s were
  3. egb19c
    egb19c New Member
    Yes, your car has the VTEC wires from the ECU to the shock tower ONLY. You just need to make sure the engine harness you use is the Si, GSR, etc...
