Quick question
CDUB103RD
IM NEW 2 DA MOTOR SWAP SHIT SO I WAS WONDERING WHAT WILL I NEED 2 PUT A B20 IN A EG SEDAN:confused:......CR NEVER BEEN TOUCH AT ALL SO ITS BONE STOCK
Same as you'd need for a B18B swap- search around the forums a bit, read up in the reference section.
what all do u have already? ull need motor, trans, axels, wiring harnes, ecu, shift linkage, motor mounts jus to name a few things if uve never done a swap before i would recomend having a shop do it or doing a lot of research
