i second the power steering not fitting.. but you never know, im not sure about the oil pan off of an SOHC fitting up to an DOHC... you might have problems with getting the pickup to line up is what im being told
Im pretty sure the oil pan wont fit but The power steering rack should. Most of the D series motors utilize the same mounting positions on the block there for all you should need is the mounts and the rack and hydro lines
