quick rotor size
Discussion in 'Wheels / Suspension / Tires / Brakes' started by PhyRe, May 20, 2005.
  1. PhyRe
    PhyRe Senior Member
    ct
    92-95 civic dx = ex front? or is it 94+ integra= ex? or are they the same and is just depends on caliper size? i know the rear is all the same. im buyin my rotors today so i dont wana get the wrong ones. thanks for the help
  2. PhyRe
    PhyRe Senior Member
    ct
    let me refrase my ? will 94+ integra rotors fit my stock front civic dx set up with rear brake conversion?
  3. phunky.buddha
    Dallas / Fort Worth, TX
    No. 94+ Integra rotors are 10.3 inches. DX rotors are 9.5 inches. The EX can have either the 9.5 or the 10.3 up front- depending on if the car had ABS or not.
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    To put the integra rotors on your car, you need the integra caliper, integra spindle, integra pads, and integra caliper bracket. (and advised you get integra brake lines, as the civics are just shy of being to short. There is too much tention on the line when you put the line bracket on)
