Not sure...
Easy way to be absolutely sure, sticker or not- lift the front end of the car off the ground. Put the car in neutral. Spin one wheel like you're driving forward. If the other wheel matches (spins forward), then you have the factory LSD. If the other wheel goes the opposite direction, you have an open diff.
