quick way to remove CV Axles?
nastynate
lowridin' Sol
I'm about to pull my motor and the only thing stopping me at this point is taking out the cv axles. I already unbolted the lower ball joints, and they dont want to separate from the spindle. I have a ball joint press, but the cv axle is directly in the way to use it. Is there any other way to separate them other than using a pickle fork?
1. Put the lower ball joint castle nut 3/4 of the way back on.
2. Make sure wishbone bolt is still in.
3. Jack up on the lower ball joint castle nut quite a bit.
4. Use a HEAVY hammer and hit the lower control arm right at the ball joint. (there is a little teet there for you to hit.)
*** Don't bother with a normal light hammer. It takes one or two good thwacks with a maw and you'll see/hear it pop out.
Works for me 100% of the time.
Don't forget to take the dampner fork bolt out before whacking away.Also a $10 ball-joint remover makes things easier.
Disconnect the LCA at the pivot, the swaybar, and the lower shock mount. disconnect the upper knuckle joint and remove the knuckle and LCA as a single unit. Changing the axle took me less than an hour, and saved me 20 minutes of whacking away at a ball joint. I've just about decimated that little teet on my integra's knuckles.
:werd: and if you screw up your threads be ready to buy a new ball joint.
use a hacksaw, thats a pretty quick way :D j/k
:werd:
Except I don't disconnect the upper knuckle. I just push stuff enough out of the way so that I can get axles in and out. Works like a charm.
:werd:
To be honest, I didn't disconnect the upper knuckle ether, I was just listing it, noting that it would make sliding the shaft out easier.
