Quick ?.....Which alternator for obd1 jdm b16a?
you can make the single overhead cam alternator work. I just put some nuts on the bolt as a washer and it works like factory, i was supprised how easy it was.
my d series alternator wouldn't fit... the holes didnt line up for the adjustment. could you let me know how this works?
95 (obd1)delsol dohc vtec,alternator didnt work.if u check on advanceautoparts.com,it will say the part number is 14447,for single & dohc...........................which alternator do i need to buy for jdm b16a OBD1.
Try the 00 Si alternator. Also, you may want to think of getting that thing from Honda cause I tried getting stuff from places like Advance and they always gave me stuff for the SOHC D series. If you go to Honda you can tell them what motor you have and they should be able to help you.
