anyone know what would cause a valve tap only on the intake side of cylinder 4,,,, its a b16b with stock cams and valve train . Would a not properly tensioned timing belt do it. and when setting the timing my crank pulley has [ | } mark and to the right | . Is the single mark lined up with the line on the timing belt cover TDC? or is it the middle of the 3 tick marks on the left?
