RA3 in a accord 96?
claes3
hello im trying to know if there possible to swap an 2.3 vtech odyssey engine in my 2.2 non vtech accord 96? and if there possible to swap a bigger engine like the 99 honda odyssey V6 3.5L? thank you
The 2.3 engine should be pretty easy. It would essentially bolt in. You'd just need to figure out the wiring. The 3.5 would be much more complicated. You'd need to do lots of fabrication...
and what about the ECU? which i should use after the swap?
