92 HATCH FULL CAGE, WHEELIE BARS, FRESH BUILT SLEEVED MOTOR 0 MILES BUILT HEAD JUN CAMS ACCEL DFI LOTS OF GREAT PARTS TOO MUCH TOO LIST WILL GET INTO DETAIL FOR SERIOUS BUYERS.. WILL TAKE TRADES OF CARS EQUAL VALUE.... CAR IS 70 % DONE NEEDS TURBO KIT, INJECTORS AND TUNING AND RUN DEEP INTO THE NINES...WITH ALCOHOL ???EIGHTS MAYBE..... WELL OVER 23K PUT INTO THE CAR.
NEW ASKING PRICE $15000..NEGOTIONABLE SOME PARTS MAYBE REMOVED TO LOWER PRICE....NO SERIOUS OFFERS WILL BE REFUSED!
92 hatch clean title....
MB one piece front end.
gutted doors with tin work
unorthodox racing chasis fabrication 12 pt cage
wheelie bars
traction bars
gsr rear brakes
cross drilled rotors all around
skunk 2 springs
skunk extended wheel studs up front
lexan dirver and passenger doors
window net
DRIVETRAIN
95 gsr block bored over .20
darton sleeves
je pistons 9.5:1 comp. with special dome coating
crower rods
knife edge crank
new honda bearings
moroso oil pan and pick up
ported and polished head
manley valves
jun spring retainers
jun stage 2 cams
custom intake manifold
custom exhaust manifold (needs flange for your specific turbo)
pro drive oil pump gear
new water and oil pump
98 type r tranny with pro drive spool
drive shaft shop stage 5 axles and hubs
front dragon fly bogarts mounted on mt 26 x 9 x 14' slicks
1 gallon fuel cell mounted in trunk
custom enclosure for fuel cell
assorted autometer gages and control pannel
accel dfi previously tuned by turbo people
msd igition
WHAT THE CAR NEEDS TO BE FINISHED:
TURBO
FLANGE WELDED TO EXHAUST MANIFOLD
INJECTORS
ASSORTED FUEL LINES
THROTTLE BODY
PROPORTION VALVE stock was removed due to custom intake manifold
RADIATOR
RUN CELL FOR WATER AIR
RUN LINES FOR WATER TO AIR
TUNING
LEXAN IF YOU WANT TO DO REST OF WINDOWS...
THE CAR WEIGHED IN AT 2030 LBS WITH A 175 LB DRIVER....WITH OLD TURBO SET UP...WENT 10.7 136 BACK IN 2001 WHEN CARS JUST BROKE 9'S
RAN OUT OF FUNDS CAR HAS BEEN SITTING FOR OVER 2 YEARS.. WAITING TO GET FINISHED..
wheelie bars
traction bars
gsr rear brakes
skunk 2 springs
window net
DRIVETRAIN
darton sleeves
crower rods
knife edge crank
new honda bearings
manley valves
jun stage 2 cams
msd igition
TURBO
INJECTORS
ASSORTED FUEL LINES
THROTTLE BODY
RADIATOR
TUNING
