Hybrid93Hatch
Member
I am having an over heating problem because my radiator fan will NOT come on. I tested the fan it works fine. Yesterday I realized the harness that plugs into the fan is nto getting any power. Today, I just pulled the fuse from the fuse box (for the radiator fan) under the hood near the battery and tested for power with the multimeter. Not getting ANY power (key turned to ON (II) position). Pulled the hazard fuse and turned the switch for the hazards on and power is there!
Where do I check now? Is there something inside the fuse box that can be bad / not working? Maybe a disconnected wire?
Thanks for any help!
