Radiator/Hose question.
Bseriesfanatic
Hey all, I'm planning on performing a b16a second generation sir-II swap into my 1995 honda civic ex equipped with the d16z6 engine. Now my question is, can I use my stock radiator? If not which radiator do I need to get? Aftermarket? If I don't have to get a different radiator, what sort of hoses will I have to use? Thanks
Stock is perfectly fine- if you feel like you need an upgrade, the del sol VTEC radiator is a direct fit.
93-97
the Del Sol VTEC was available 94-97
You will need to use B-series radiator hoses from the sol vtec or integra. the dseries don't quite bend correctly on the engine side.
