Radiator hoses 4 b16 swap into civic EK4 96??
Discussion in 'HYBRID -> EG-EK / DC' started by loverboy, Oct 11, 2006.
  1. loverboy
    loverboy Junior Member
    Hi guys !
    I need the hoses 4 my swap. I know that I need the lower from Integra GSR and the upper from Type R.
    I saw in ebay some hoses which do u recommend ? maby non so recommend on others:
    1. OBX
    2. SAMCO
    3. HAYAME
    Do u know if the lower hose of the Type R will fit 2?
    Thanks
  2. B18C1civic96
    B18C1civic96 Member
    5-CARS IN FRONT OF YOU
    use the hoses for a 99-00 civic si and you can use your stock rad. or a si's
  3. tip
    tip Senior Member
    Ennis Texas
    i have the samco kit and like it alot............looks good better material and not that much more
  4. loverboy
    Do u know if I have the two cores radiator like the one in the SI in my EK4 civic coupe D16y8 engine?
  5. reikoshea
    Dallas, TX
  6. loverboy
    Im steel wondering about this question ?
  7. tip
    tip Senior Member
    Ennis Texas
    look at the end of it and you should be able to tell....!!!!
  8. loverboy
    Strait 2 the point !
    I need someone that have done a b16A/B into civic EK4 96 (engine d16y8) 2 tell me which rad' hoses do i need ?? (the SI's or something else)
    which hose is recomended (obx, samco, hayate, others)?
    Thanks
  9. tip
    tip Senior Member
    Ennis Texas
    what ever brand you want and for the si. more then likly you have a single core and will need worm style hoes clamps to make them work unless you spring for a aftermarket or si rad.
