radiator is kicking on...
slimtdx
got a 93 civic lx w/ a b18c swap. engines running smooth...but the radiator fan isnt kicking on. the upper radiator hose gets hot as hell, as well as the lower radiator hose. the thermostat is brand new. the radiator fan switch is brand new. im not hear any weird noises from the water pump, not water on the ground near it. havent check it weep holes itself yet, but i doubt its it. any ideas fellas?
get an electric control switch and wire it to your ignition. that way it starts when the car is on.
Is your fan relay good? Check your grounds. and power supply. If your relay is good, your switch is new, and you have power and the fan is grounded you shouldn't be having problems.
