radiator problems help
efb20b
wat kinda of radiator should i use for my car its a 89 civic with a b2ob
go to napa... they have a large radiator (auto radiator i believe) but it fits perfectly and is only 83.00. i had to do that recently as my stock radiator was slightly shorter (widthwise) but alot more expensive than the longer width version. plus if you are rocking a manual tranny you can use the stock auto tranny cooler as an oild cooler for your engine!
i forgot to give you the part number to asdk for at napa.
here it is....
big numbers : 2106
small numbers 432106
i am assuming the 6 digit is the actual p/n i can send you a pic of the side of the box for reference if needed.
jeremy
