radiators
Discussion in 'Integra' started by K-Mon3y, Jan 26, 2007.
  1. K-Mon3y
    K-Mon3y New Member
    has anybody upgraded their radiator to alluminum is dat the best choice for a dd or an oem fit or can u jus upgrade the fans to make it cool faster jus lookin for a good setup for my 91 teg
  2. myah
    myah Neu Impact Performance
    ks
    yeah i got a fluidyne radiator good fit in my 95 gsr
  3. K-Mon3y
    K-Mon3y New Member
    wat about a/c i heard dat if you switch out your radiator some dont run a/c or heat dont care much bout the a/c but heat in da winter time is a must
  4. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    why do you want to swap it out? It does not net any hp gains
  5. igotnothin
    igotnothin New Member
    harford co MD
    cause it will be shiney......:cool:
  6. K-Mon3y
    K-Mon3y New Member
    well my radiator is goin bad and if imma upgrade my car im goin to do it all da wa plus i'm goin to b adding a lot of goodies for my jdm b16 engine so it will b helpful to keep da temp low
