im finishin up my 87 crx with a b16 swap...well u need the knucles from a 91 integra on the hub assemblys for it to fit...but i ran into a slight problem...the 91 integra hub assemblys are made for coil overs and dont fit on my crx...can anyone help me out here
You have to use the 86-89 Integra knuckle and hub assemblies. The 91 Integra ones will not work. You will also need to make hybrid axlesof some sort. I never got far enough in my swap to find out the length that the shafts have to be but HASport makes shafts and complete axles. If you buy just the shaft you will still have to source integra CV joints and put the whole combination together. One day we will find out what donor car can lend the axle shafts and if you find out please let me know.
