Ranger pics
Discussion in 'Auto Multi-Media' started by BodyDroppedNikes, May 3, 2006.
  1. BodyDroppedNikes
    caught in a mosh...
    as some of you know i just bagged the rear of my 95 Ranger Splash. heres some pics i took:
    heres what the rear tires look like up in the fender wells when aired down:
    heres the bed with everything in it including the gas tank which was relocated to the bed, all the valves, the tank, compressor and the rear notch and bridge. i painted the notch, bridge and the differential black. also you can see that the tailgate handle and Ford emblem has been shaved on the tailgate in this pic:
    and finally heres some pics of the truck aired out in the rear:
    so there it is. im halfway bagged. oh and in case you are wondering where the bags are, they are located outside the notch. enjoy!!
  2. reikoshea
    Dallas, TX
    I'll never understand the mini-truck guys. My friends that arent into V8s are into S-10s (and the thought of an LS1 in said S-10).
    Pretty nice though. You dont see many splashs around, especially not bagged splashs.
  3. brian11to1
    brian11to1 Senior Member
    yea, it looks like a sad puppy running around w/its tail between its legs.
    shoulda waited til you could do the front as well.
  4. Celerity
    Celerity Well-Known Member
    That's a lot of gear to make just the ass drop. Are you going to need to like, double that stuff to make the front drop too ?
  5. BodyDroppedNikes
    caught in a mosh...
    nah the front wont take long. just gotta get the bag brackets and weld them in, remove springs up front, install bags and run the air line and thats it...pretty much.
    and the reason why the gas tank is in the bed is that it hangs below the frame rails and since its going to lay frame when done, i dont want the gas tank to hit the ground and have a hole get dragged thru it.
  6. Seany-izzle
    Seany-izzle New Member
    In a fucking house.
    when you plannin on doing the fronts, soon?
    looks good mang, now all you need is some paint, wheels, and a new front grill. Do i smell custom fuel door?
  7. TommyTheCat
    TommyTheCat Gonzo Scientist
    Minneapolis, MN
    Fuel door? Just get a fuel cell to clean up that bed.
    What size line are you running in/out of those bags?
  8. BodyDroppedNikes
    caught in a mosh...
    yeah a fuel cell is in the near-ish future so is billet grille and new headlights
    the yellow lines coming out the tank are 5/8" lines which goes into 3/8" valves and out to the bags via 1/2" lines
  9. YouKnowWhoIBee
    YouKnowWhoIBee my avatar is better.
    Maryland
    haha TPP dont use paint!
  10. Seany-izzle
    In a fucking house.
  11. jamesA
    His life motto IS Primer is Finer. :p
  12. reckedracing
    reckedracing TTIWWOP VIP
    NY
    hmmm, it still looks like its sitting kinda high
    can you drag frame?
  13. jamesA
    Not yet, he's about 1.5-2" off the ground fully dropped in the rear.
  14. TommyTheCat
    Minneapolis, MN
    Just get some 2-3" titanium drag blocks to fill that gap. Drop the bish on the highway and make sure no one's behind you :p
