RC FUEL INJECTORS 550cc
LOS222
Member
I have a H22 swap in my 96 accord and I'm having a turbo installed. Do I need to get RC Injector Plugs with my setup? :worthy: :worthy: :worthy:
There are many different brands other than RC engineering, but yes, you defidently have to upgrade your injectors. It depends on how much hp you plan to make.
No, I think you misunderstood the question... I am getting those injectors. Do I have to get "injector plugs" for my injectors with the setup I have?
I know it's getting late but, sombody gots to know the answer to this??? :(
[post=546219]Quoted post[/post]​
no i got rc440 cc and they just pluged in
obd2 harnesses need the rc plugs. they are basically obd1 copies. so, if you used an obd2 wire harness, you will need to pick up the rc injector plugs (or cut them off an obd1 harness)
Thanks Pissedoff for all your help on all my questions so far. :D
