real quick before i start putting my motor back together. honing.
TurboMirage
That’s how you get ants
VIP
so the spare block came from a running/driving mirage with absolutely no oil or coolant leaks, perfect compression, and all the internals were mint. the cylinders are in great shape and you can see the existing cross thatch. 100K miles or so on it. amazing shape.
i have new forged pistons/rings on OEM rods, all new matched bottom end bearings too. all the bearings looked awesome with barely any visible wear at all.
knowing what i do, my first instinct is to hone it, but i figured i would ask. the cylinders are within spec according to my dial gauge.
i can provide pictures if needed ;)
hone it your gonna hate your self if ya have to take it all back apart again. trust me i know
If theres no apparent deep scoring, all you need to do is to use a soft ball hone and lots of oil to remove any rust, and get some good cross-hatching going. Make sure that after you get it honed, you keep the bores coated in oil until you assemble everything.
