Rear Brake Swap
Discussion in 'Wheels / Suspension / Tires / Brakes' started by 93solman, May 14, 2003.
  1. 93solman
    93solman Member
    Ok, here's the deal. I am going to do a disc brake conversion to my 93 Sol S (money is the deciding factor of when). However, my questions are these:
    If I'm going to the rear brakes off of a VTEC sol, do I need to do the 15/16 master cylinder? And if I do,(or if it's just highly recommended) do I also need a new proportioning valve and brake booster? my bro(lsvtec) said to talk to the people that have done this swap before. Just let me know how you guys fidured it out, and your results.
  2. E_SolSi
    the cylinder and booster arent needed but the 4040 proportioning valve is
  3. Baker
    Baker Senior Member
    Schaumburg, IL
    none of them are NEEDED but its ideal, you don't need to do the proportining valve right away but get to it as soon as possible otherwise the swap was pretty pointless, the rest should be done but it can wait
  4. 93solman
    93solman Member
    Can I get the 4040 proportioning valve from any of the integras?
    and parking brake cable for that matter?
  5. E_SolSi
    prop valve yes
    ebrake cables im not sure
  6. 93solman
    93solman Member
    the 4040 is the non-ABS one, right?
  7. snowboarderguy44
    snowboarderguy44 Member
    So-CaL Riverside
    4040 is 4-wheel disc ....... unsure wut designates ABS non-ABS ........ ive done the swap on my EJ1 it works great ......
