rear brakes help
Discussion in 'Civic and del Sol - EG and EK' started by RiCe1o5, Oct 31, 2011.
  1. RiCe1o5
    RiCe1o5 New Member
    I'm having issued with my top spring on my rear brakes while installing new shoes any one have t
    HTML:
    ips
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Disk swap? :D
  3. bluejcivic
    bluejcivic New Member
    you have to remove that spring in order to flip up the caliper to replace the pads, just unbolt the ebrake cable and use some pylers to remove the spring. good luck
  4. RiCe1o5
    RiCe1o5 New Member
    My issue now is putting it back on i got all the parts on but the top spring is hard to pull over
  5. 98EkSi
    98EkSi New Member
    You should be able to remove the caliper without disconnecting the E brake cable, if we are talking about rear disc brakes.
  6. RiCe1o5
    RiCe1o5 New Member
    The problem I'm having is putting the top spring back into the shoes in the rear brakes
  7. JoeDaddy
    JoeDaddy New Member
    Dallas, TX
    put the top spring on first then assemble the pads, put the lower spring on last much easier in my opinion that's how i did mine
  8. dc4dude
    dc4dude Member
    chicago, il
    vise grips.. and BAAAAAAAAAAAAAAALLLLLLLLLLLLLLLLSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!!
  9. 98EkSi
    98EkSi New Member
    Yep. There is also a drum brake spring tool you can get to install and remove the springs. Should be able to find one at like Auto Zone ect. Pliers or vice grips will also work, that is how I did them before I got the tool.
