Rear disc brake conversion for 96-00 civic
Status
Not open for further replies.
Has anyone done a disc brake conversion from drums with the si brake componets on 96-00 civics? I know I need to get the rotors, calipers, caliper mounting brackets, hub/bearing assembley, and splash guards for each rotor. but do i need to change the hydraulic lines to make it compatible with the calipers? also, is the e-brake cable compatible with the si rear calipers as well? if anyone could offer any insight, that would be great.
i did it on a 93 coupe the parking brake cables are different.
i used the rear lines off the teg rear sus. i used
i changed the hole trailing arm cause i had them
if you need any more help let me know
Nick Bredemeyer
Please refer to our FAQ. There is no need to post your topic more than once.
This topic has been closed by a moderator. Please continue your question in the other thread that you started.
Thanks, Moderating Team
:locked:
Status
