rear disc brake swap
MRG719
Will rear trailing arms from a 94 integra fit my 91 dx hatch everything looks the same bushings apper to be the same size. I got everything I need except for prop valve
Yeah, they will. Don't listen to the BS online that says you need 90-93 DA arms. They are the same design on Civic 89-00 (don't know about the weird 88s)/Integra 90-01 including Type R. The only thing that will probably be different will be the rear compensator arms, the ones for toe adjustment, oh and the lca if you even have those from the donor. I recently put 93 Si rear arms on mine and that was the only difference.
