Rear Disc Brakes
Discussion in 'Wheels / Suspension / Tires / Brakes' started by MugenCRX, Apr 7, 2003.
  1. MugenCRX
    MugenCRX Senior Member
    Thornton CO
    Does anybody know if the rear disc brakes from SI model CRX's are swappable onto an HF model, and if so how would I do it and what do I need to do it?
    Thanks for the responses,
    -Jeff :ph34r:
  2. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    if they are both the same gen i think you can do it you just need the Lower control Arms, the calipers, discs, emergency brake cables, brake booster, and the brake lines. i think thats it.
  3. whatdahieu
    whatdahieu Senior Member
    is your hf brakes aluminum or is that just the 1st gen's?
  4. legutki
    legutki Senior Member
    i got a new project
  5. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    you don't need the brake booster tho
  6. Civic_88ls
    Civic_88ls Senior Member
    everett, wasington
    It will fit but u would need the whole trailing arms and the emergency brake cables. there is alot of sites out on the internet that will show u what to do. this site helps and shows u what to do
