Rear disc conversion question.
Discussion in 'Wheels / Suspension / Tires / Brakes' started by Jared759, May 5, 2008.
  1. Jared759
    Jared759 Well-Known Member VIP
    SC
    I have everything I need except rear brake hoses.
    I know you can use the 99-00 si hoses, could I use integra rear brake hoses?
    There is an insane amount of integras in the local junkyard and I was wondering if I could use those cause I can get them for cheap.
    This is on a 97 EX coupe.
    Thanks
  2. Jared759
    SC
    anybody?
  3. 92civicb18b1
    92civicb18b1 The Trisexual
    Not sure, But I love working at a shop. I'd just make brake lines. :D
  4. efhondakid
    Akron-Canton, Ohio
    Just use your old lines, they are the same.
  5. Jared759
    SC
    you sure?
    The brake post on honda tech said that they were different
  6. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    They are different, in length. Are you talking about the soft line from the hard line to the caliper?
  7. Jared759
    SC
    Yea.
    If the integra ones would work I can just get them from the junkyard when I go today.
  8. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
  9. Jared759
    SC
    If I can't get them from the junkyard I'll get back to you.
    Lol.
    But does anyone know if the integra lines will work?
  10. Jared759
    SC
  11. Jared759
    SC
    I'm just going to get the integra brake hoses.
    hell if they don't work then I'm not out much.
    Might even be able to get them for free.
  12. autox 89 dx
    autox 89 dx Member
    SF bay area
    i did the swap on my 89 ef and the integra ones were to short I had to get Goodrich brake lines off a 92-95 with disc brakes there longer and the mounting brakets on the lines are adjustable wich the stocks are not made it so much easier
  13. Jared759
    SC
    Just got both brake cables all the bolts and brackets and 2 brake hoses for $15
    man i love the mexican junkyard
  14. Jared759
    SC
    Ok started on my rear disc conversion yesterday, started out fun but got kinda troublesome.
    The bolts that hold the spindle on (torx bolts) rounded off, so my buddies and I took the trailing arms off the car. Luckily we have 2 milling machines so it made drilling out the bolts easy.
    We re-tapped the holes, everythings good. The trailing arms are re-installed and everything bolted and torqued.
    I have all the brake lines and hoses ran, still need to install the proportioning valve and get some pads. Ment to get them yesterday but it was 9:00 before I knew it, so advance was closed.
    Going to get them when I get out of school today and get paint for my calipers (since they came painted a horrible orange color.)
    Will post up pics when I'm done.
  15. YBLEGAL
    NW Indiana
    niice man. much faster than my rear disc conversion of my 00 coupe....
    but i'm doin more, and i'm basicly a noob. heh ;)
  16. Jared759
    SC
    we have the same creeper.
    lol
    looks good.
    Lot of work too.
  17. Jared759
    SC
    I found a problem yesterday, the prop. valve is the wrong one, went to the junkyard to see if I could find one, no luck.
    So my car isn't drivable until I get a new one.
    This sucks.
  18. YBLEGAL
    NW Indiana
    consider an adjustable proportioning valve?
    i'm doing that too. should be fun :)
  19. Jared759
    SC
    I thought about it, but I'd rather get a prop. valve thats already proportioned correctly.
    My research on Prop valves have came up with this
    Prop valves that are the same as the 99-00 SI(will work with rear disks)
    99-00 SI
    96-00 2 Door DX
    96-00 3 Door DX
    96-00 2 Door HX
    96-00 3 Door CX
    Prop valves that are NOT the same as the 99-00 SI(will NOT work with rear disks)
    96-00 4 Door EX(With or without ABS)
    96-00 2 Door EX
    96-00 4 Door DX
    96-00 4 Door LX A/C
    96-00 4 Door LX ABS
    If anyone has anything to add to this just post it up and I will change it.
    This is looking up part numbers and matching them with the SI part number.
  20. Jared759
    SC
    Also the integra rear brake hoses(the soft lines) worked for my trim.
