Originally posted by ihitvtec@May 23 2003, 01:43 PM
i have a 90' civic hatch and i want to get rid of my drums. i want a rear disc conversion but i want to get the wilwood kit for the back and that comes with the rotors,calipers,and the brake lines what else do i need
Description
Finally a drum to disc conversion that's affordable! This package allows you to convert your rear drum brakes to discs without having to change the trailing arms. Using aluminum adapter brackets, this kit uses an upgraded 11" rotor to further increase braking performance. Kit contains all the necessary parts to convert to the disc brakes, including, OEM style rotors, calipers, parking brake cables, pads, braided steel brake lines, all bolts etc. Requires using 15" or larger wheels.
