Rear disc question
FSTBLUOVL
What would happen if i did a rear disc swap on a 1994 dx and did NOT use the booster,mc and p valve from the integra,would the brakes even work,ive searched and it says to swap theae parts too ,but it doesent say why... Thanks guys
the most vital parts other then the trailing arm assemblies are the e-brake cable and the prop valve. you don't need the MC or booster
I've done the swap on a 96dx without replacing the Prop valve and it worked just fine.
