Just wondering exactly what kind of work is involved in putting rear discs on my 84 CRX (Integra parts as I have already read in the FAQ). I can handle almost any mechanical/fab issue but I'm wondering if there's mod's required to the e-brake cables or hydraulics. At least if I have a good idea what tools and supplies I'll need I can knock this mod off in a weekend without putting my car out of commission for any extended length of time - as it is my daily driver. BTW: I searched all sorts of keywords but apparently the search function doesn't like me The reason I want to do this: I HATE drum brakes. I have a nice set of wheels for this car with "high-brake-visibility" but can't stand looking at drum brakes. And I like to hit the twisties around here whenever I can and tend to get a little hard on the brakes. It's only a matter of time until I kill my drums so I'll fix the problem before I kill it ^_^
you need 1g teg ebrake cables, rear brake lines (the CRX ones won't screw into the calipers), and you should use the teg master cylinder/brake booster
