I bought a rear disk swap on ebay. Had it powder coated, poly bushings and installed. When I went to put on the rim the lug pattern is off. I need a 4 x 100 and its a 4 x 114.3. The car is a 95 del Sol. The swap said JDM rear conversion.
So a new hub is needed. Which one do I get? Integra or Civic?
My concerns are spindle to bearing size. Length of spindle to hub and location of hub mounting flange for brake alignment.
Anyone run into this or know where I can get come technical specs.
